U4GM Guide: Best Book of Specialization Farming Spots in PoE 2
- Hartmann846
3 meses 1 semana antes #60908
por Hartmann846
Missed three Books of Specialization on my first run through Act 1 and didn't notice until I hit maps. By then my swap bar felt like wet cardboard compared to my main loadout. If you're hunting the Book of Specialization in Path of Exile 2 and want every guaranteed copy before you start farming bosses or burning a Divine Orb on respecs you didn't need, here's the short version - grab the side quests first, then chase the boss drops, and don't sleep on the 24-point cap.
What the Book of Specialization actually doesEach book hands you 2 weapon set passive points. Those points only kick in for the weapon loadout you assign them to, which is the whole reason the system exists. You can run a sword-and-board melee setup on slot one and a bow on slot two, and your skill tree shifts the second you swap. Cap is 24 points total - that's 12 books across the campaign. Miss a few and your secondary bar will feel underleveled forever.
Where to get the Book of Specialization in PoE 2Quest rewards are your bread and butter since they're 100% guaranteed. In Act 1, finish The Lost Lute in Ogham Farmlands - Una hands you one when you return her instrument. Act 2 has two: Tradition's Toll in Deshar (you'll do a Serpent Clan ritual), and Clearing the Way in Khari Crossing, which asks you to kill Ak Thi, the Final Sting and Anun Dr, the Sandworm before talking to Risu at the Khari Bazaar.
Boss farming fills the gaps. The Crowbell in the Hunting Grounds is the easiest early target. Kabala, Constrictor Queen in Keth has a better drop table but it's still RNG. Mighty Silver Fist in the Jungle Ruins (Act 3) is the most consistent mid-game source - not gonna lie, that fight chewed through a few of my portals before I cleaned it up.
Other ways to bump up your weapon set passivesA few rarer items pull the same trick. The Sacrificial Heart drops from Vaal Goliaths in Act 3 and gives +2 weapon set points at ritual sites. The Mist-Shrouded Tome works like a quest-style consumable. Tattoo of Hinekora is the endgame option - way harder to get, but it stacks with everything else. Take the drop rates with a grain of salt since GGG keeps tweaking them patch to patch.
Common mistakes and stuff the wiki won't tell youGlobal buffs allocated inside a weapon set tree only stay on while that loadout is active. So if you grab a movement speed node on your bow set, swapping to your melee bar shuts it off. Use these points for weapon-scaling stuff - phys damage for axes, projectile speed for staves - not generic utility. That's where most new players bleed value.
Honestly, missing two or three books in the campaign locks you out of the final tier on most weapon clusters, and there's no catch-up mechanic I've found. Check your quest log in Ogham Farmlands and Deshar before moving on. If you're stocking up on currency or grabbing items to round out a build, sites like U4GM are worth a look while you grind. Get the books early - your future maps-self will thank you.Farming weapon set passive points in PoE 2 has become its own little side game for me - Clearing the Way against Ak Thi and Anun Dr at Khari Crossing alone pushed my dual-loadout build into a whole new tier. For the gear and consumables I need between boss runs, U4GM at www.u4gm.com/path-of-exile-2/currency is where I usually restock, since it lets me focus on actually testing weapon swaps instead of grinding currency for hours.
Tiempo de carga de la página: 0.235 segundos
